Geometry... Stuff to do with points
1433
02-28-2018 10:33 PM
DanPatterson_Retired
3 0 1,433
Geometry  Perhaps its due is overlooked.
A pictoral of some of the things you can do with a set of points with a basic license in ArcMap and PRO with a bit of python and a toolbox to house the scripts in.
:---- (1)  -------------------------------------------------------------------------------------------------------------
Begin with some points
Random they are, no order.
:---- (2)  ------------------------------------------------------------------------------------------------------------------
Put order to the set
A radial sort was performed so that the mess was ordered by their angle relative to the x-axis.
Lines were drawn to the center of the cloud (just because)
:---- (3)  ------------------------------------------------------------------------------------------------------------------
What do we have now
Since the points are ordered, connect the dots.
:---- (4)  ------------------------------------------------------------------------------------------------------------------
Lets look at things conventionally
Everyone loves a convex hull.  It encompasses the points as a group.  There are other containers.
:---- (5)  ------------------------------------------------------------------------------------------------------------------
But some of the points are far from the center
A quick little negative buffer to only keep the points within 90% of the average distance to the center.
:---- (6)  ------------------------------------------------------------------------------------------------------------------
Convexity.... A different view on the data
Switching the selection in the above, then connecting the dots gives us a convex-ish hull..
Hmmm I wonder if you can change the rules to get a different view?
:---- (7)  ------------------------------------------------------------------------------------------------------------------
Every cool map has texture
Fill in boundary, obliterate the dots and 'forest' fill.  Just because we can
:---- (8)  ------------------------------------------------------------------------------------------------------------------
Connecting each point to its closest
:---- (9)  ------------------------------------------------------------------------------------------------------------------
Connections to 3 closest
Starting to see groupings and spaces.
:---- (10)  ------------------------------------------------------------------------------------------------------------------
Trees are useful (MST)
:---- (11)  ------------------------------------------------------------------------------------------------------------------
Make patterns from a single point (Ulam spiral)
:---- (12)  ------------------------------------------------------------------------------------------------------------------
Archimedes only needed a single point
:---- (13)  ------------------------------------------------------------------------------------------------------------------
:---- (14)  ------------------------------------------------------------------------------------------------------------------
About the Author
Retired Geomatics Instructor at Carleton University. I am a forum MVP and Moderator. Current interests focus on python-based integration in GIS. See... Py... blog, my GeoNet blog...
Labels
