Free advanced tools ... Bounding Circles
1807
08-08-2019 06:00 AM
DanPatterson_Retired
2 0 1,807
 Free basic functionality.
Once again, functionality that is normally restricted to the Standard or Advanced ArcGIS Pro license.
Previously
 - Feature to Point
 - Feature Extent to Poly Features
 - Free Tools : Frequency and Statistics
 - Free Tools : Convex Hulls
Help topics
 - Feature Envelope to Polygon
 - Frequency
 -  Convex hull in Minimum bounding geometry
 -  Feature to Point
 -  Polygons to line
 -  Circle in Minimum bounding geometry
Implementation
The implementation here is largely based on Welzl's algorithm.
Another container.  I did the rectangular ones, now the circle, then the ellipse.
Still, numpy, python and arcpy all play nice.  Check out the code.  All seven tools are implemented in one toolbox and controlled by one script.
Output examples
A circle is implemented as an ngon with 180 sides (2 degree increments) as polygons.
I could have put in a bunch of options in the tool to select the density and output type, but students (and others) wouldn't learn to 'tweak' code.  You can always do your own toolbox or use esri's
WARNING
I have code that checks the validity of the file paths.  If you input or output paths contain spaces or other flotsam, then the tool will not produce any results.  Why?  Too many questions where file paths are the problem.  I won't 'enable' the current practice
Download
You can copy the contents of the folder on my GitHub pages.  No fancy install, just create a folder, throw the stuff in, load the toolbox and give it a try.
Got any geometry related or analysis tools you need implemented? let me know
Free_Tools
About the Author
Retired Geomatics Instructor at Carleton University. I am a forum MVP and Moderator. Current interests focus on python-based integration in GIS. See... Py... blog, my GeoNet blog...
Labels
