Derive featureclass properties quickly... more than geometry
556
06-17-2019 06:00 AM
DanPatterson_Retired
0 0 556
Featureclass Properties
  • Feature class info
  • Field info
  • Geometry info
  • Geometry decomposition
The code... I will update here.
Information functions for featureclasses
A quick solution to obtain geometry information.  Other info can be added.
fc_info(in_fc, prn=True)
FeatureClass:
   C:/Arc_projects/CoordGeom/CoordGeom.gdb/Shape2
shapeFieldName  OIDFieldName  shapeType spatialReference
Shape           OBJECTID      Polygon   NAD_1983_CSRS_MTM_9‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Those pesky fields.  Don't want to open up ArcGIS Pro to find out?  Already got Spyder (or your Python IDE) open? Use this.
fld_info(in_fc, prn=True)
FeatureClass:
Name          Type         Length Nullable  Required
OBJECTID      OID               4 False     True
Shape         Geometry          0 True      True
Shape_Length  Double            8 True      True
Shape_Area    Double            8 True      True
CENTROID_X    Double            8 True      False
CENTROID_Y    Double            8 True      False
INSIDE_X      Double            8 True      False
INSIDE_Y      Double            8 True      False     ‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
How many shapes? Are they all singlepart? How many points?  Which points connect to make what shape?
fc_geom_info(in_fc, SR=None, prn=True, start=0, num=10)
Featureclass:
   Shape    Parts   Points From_pnt   To_pnt
       1        2       21        0       21
       2        2       18       21       39
       3        1        4       39       43 ‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Same as above... but where do the parts stop and start? Everyone loves stats! Right?
fc_composition(in_fc, SR=None, prn=True, start=0, end=50)
Shapes :   3
Parts  :   5
  max  :   2
  min  :   4
  median : 9
  max  :   11
     IDs     Part   Points From_pnt   To_pnt
       1        0       11        0       11
       1        1       10       11       21
       2        0        9       21       30
       2        1        9       30       39
       3        0        4       39       43
So simple, so...  _common give it a try
More offerings in … npGeo ... numpy geometry
Oh yes... Nice documentation too...
About the Author
Retired Geomatics Instructor at Carleton University. I am a forum MVP and Moderator. Current interests focus on python-based integration in GIS. See... Py... blog, my GeoNet blog...
Labels
