Define Projection vs Project... a visual guide
6587
09-06-2016 11:57 PM
DanPatterson_Retired
10 2 6,587
There is ... still ... confusion regarding the proper use of the  Define Projection Tool versus the Project Tool
"my data don't line up..."
"I am sure about the coordinate system..."
"everything is far apart onscreen..."
We have all been there.  The written descriptions don't seem to catch on, so a visual guide might be what is needed.
Prior to proceeding... make sure you have seen the ...References... at the end of this section... that is what you need to understand.
So with tongue firmly planted in cheek...
Existing coordinate systemDesired coordinate systemTool to useResult
Project Tool
Project Tool
Wrong Geographic Transformation
The choice really depends on:
  • what you know you have... not what you think you have...
  • what you really need...
  • applying the correct tool...   if it doesn't work out, undo what you did... locate the originals... read the metadata
  • understanding what you got and why.
References
And to cover some of the other combinations and permutations, just remember....things can get worse, before they get better...
2 Comments
NeilAyres
Your visuals are excellent as usual. Thanks you for compiling all the links to Define, project, Coord systems etc etc.
If only people would read this stuff before they go and mess up their data by Defining, when they really need a Project.....
DarrenWiens2
Maybe need one more line where Existing CRS = None (but data is already in Orange), then Orange, then Define, then Orange.
About the Author
Retired Geomatics Instructor at Carleton University. I am a forum MVP and Moderator. Current interests focus on python-based integration in GIS. See... Py... blog, my GeoNet blog...
Labels
