Aggregation of raster data
3425
09-01-2016 07:08 AM
DanPatterson_Retired
3 0 3,425
The aggravation of aggregation ...
               Raster with some classes                                                 Aggregation using maximum
No Spatial Analyst??? A raster is just a big array... hmmmm. I wonder.
What is available at all license levels?
Not on the list?  There are examples of how to get other geometries to array format elsewhere. But everyone knows about old school ascii.  Splurge on disk space... ascii files are easy to edit.  There are many options available to get data into array format.
Code section
ASCII example...
Demo code...
This simple sample code should give you some ideas.  In this version, edge considerations are not accounted for, so should that be an issue, you can pad the array with an appropriate collar.
Script:  aggregate_demo.py
Modified: 2016-01-30
Author:  Dan.Patterson AT  carleton.ca
Purpose:  To demonstrate aggregation of raster data without the
spatial analyst extension.  A sample raster is created and methods
to convert an array to  a raster and vice versa are shown.
Notes:
- RasterToNumPyArray(in_raster, {lower_left_corner},
                        {ncols}, {nrows}, {nodata_to_value})
  arr = arcpy.RasterToNumPyArray(rast)
- NumPyArrayToRaster(in_array, {lower_left_corner}, {x_cell_size},
                    {y_cell_size}, {value_to_nodata})
  rast = arcpy.NumPyArrayToRaster(a, arcpy.Point(300000,5025000),
                                  10,10,-9999)
  rast.save(r"F:\Demos\raster_ops\test_agg")
    # esri grid, or add tif, jpg etc
import numpy as np
from numpy.lib.stride_tricks import as_strided
np.set_printoptions(edgeitems=3,linewidth=80,precision=2,
                    suppress=True,threshold=50)
from textwrap import dedent
import arcpy
arcpy.env.overwriteOutput = True
def block_a(a, block=(3,3)):
    """Provide a 2D block view of a 2D array. No error checking made.
    Columns and rows outside of the block are truncated.
    a = np.ascontiguousarray(a)
    r, c = block
    shape = (a.shape[0]/r, a.shape[1]/c) + block
    strides = (r*a.strides[0], c*a.strides[1]) + a.strides
    b_a = as_strided(a, shape=shape, strides=strides)
    return b_a
def agg_demo(n):
    """Run the demo with a preset array shape and content.
       See the header.
    a = np.random.random_integers(0,high=5,size=n*n).reshape((n,n))
    rast = arcpy.NumPyArrayToRaster(a,x_cell_size=10)
    agg_rast = arcpy.sa.Aggregate(rast,2,"MAXIMUM")
    agg_arr = arcpy.RasterToNumPyArray(agg_rast)
    # --- a_s is the strided array, a_agg_max is the strided array max
    a_s  = block_a(a, block=(2,2))
    a_agg_max = a_s.max(axis=(2,3))
    frmt = "\nInput array..\n{}\n\n" \
          "Arcpy.sa aggregate..\n{}\n\n" \
          "Numpy aggregate..\n{}\n\n" \
          "All close? {}"
    yup = np.allclose(agg_arr,a_agg_max)
    print(dedent(frmt).format(a, agg_arr, a_agg_max, yup))
    return a, agg_arr, a_s, a_agg_max
if __name__=="__main__":
    """ Returns the input array, it's aggregation raster from
    arcpy.sa, the raster representation of the raster and the
    block representation and the aggregation array.
    n=10
    a, agg_arr, a_s, a_agg_max = agg_demo(n)
This is a sample ascii file so that you can
see the numeric inputs and structure of
the ascii header and its data.
ncols         10
nrows         10
xllcorner     300000
yllcorner     5025000
cellsize      10
NODATA_value  -9999
0 0 2 5 -1 3 5 2 5 0
-1 -1 2 1 1 -1 -1 4 0 4
4 5 5 5 1 4 1 1 2 2
1 1 3 1 2 0 5 -1 2 3
1 1 5 2 4 5 4 2 5 -1
2 1 0 -1 2 3 2 1 5 1
3 1 5 5 0 3 -1 3 -1 2
1 -1 0 5 2 5 2 1 -1 2
5 4 4 5 2 3 0 5 4 0
1 1 3 5 4 -1 4 5 1 5
Does it work with big rasters?
Does it support other summary statistics?
Of course, I covered the details of raster statistics in an earlier post.
That's all for now...
About the Author
Retired Geomatics Instructor at Carleton University. I am a forum MVP and Moderator. Current interests focus on python-based integration in GIS. See... Py... blog, my GeoNet blog...
Labels
