Before I forget.
A brief introduction to array broadcasting in numpy.
# -- Two polygons
a
array([[ 0.00, 10.00],
[ 1.00, 13.00],
[ 3.00, 14.00],
[ 2.50, 13.00],
[ 1.00, 11.50],
[ 0.00, 10.00]])
b
array([[ 1.00, 11.50],
[ 2.50, 13.00],
[ 4.00, 12.50],
[ 3.00, 11.00],
[ 2.00, 11.00],
[ 1.00, 11.50]])
Which look like this.
The code is somewhat simple but requires some explanation.
The code is basically one line with the more important documentation.
def _adjacent_(a, b):
"""Check adjacency between 2 polygon shapes on their edges.
Parameters
a, b : ndarrays
The arrays of coordinates to check for polygon adjacency.
The duplicate first/last point is removed so that a count will not
flag a point as being a meeting point between polygons.
Note
Adjacency is defined as meeting at least 1 point. Further checks will be
needed to assess whether two shapes meet at 1 point or 2 non-consequtive
points.
s = np.sum((a[:, None] == b).all(-1).any(-1))
if s > 0:
return True
return False
Lets break down line 18.
a[:, None] == b # -- `a` is broadcast so that each segment can be compared to `b`
array([[[0, 0],
[0, 0],
[0, 0],
[0, 0],
[0, 0],
[0, 0]],
[[1, 0], # -- one match
[0, 1], # -- one match
[0, 0],
[0, 0],
[0, 0],
[1, 0]], # -- one match
[[0, 0],
[0, 0],
[0, 0],
[0, 0],
[0, 0]],
[[0, 0],
[1, 1], # -- both match --
[0, 0],
[0, 0],
[0, 0],
[0, 0]],
[[1, 1], # -- both match
[0, 0],
[0, 0],
[0, 0],
[0, 0],
[1, 1]], # -- both match
[[0, 0],
[0, 0],
[0, 0],
[0, 0],
[0, 0],
[0, 0]]])
# -- next ... reduce the dimensions by 1
array([[0, 0, 0, 0, 0, 0],
[0, 0, 0, 0, 0, 0],
[0, 0, 0, 0, 0, 0],
[0, 1, 0, 0, 0, 0],
[1, 0, 0, 0, 0, 1],
[0, 0, 0, 0, 0, 0]])
# -- next ... and one again. Note -1, means the last axis
array([0, 0, 0, 1, 1, 0])
# -- finally, the comparison has been reduces from a 3 dimensional array, to 2D to 1D
# -- the result
# two points which `a` meets `b` at points 3 and 4 (good old `nonzero`)
np.nonzero((a[:, None] == b).all(-1).any(-1))[0]
array([3, 4], dtype=int64)
# if we reverse `b` and `a`
np.nonzero((b[:, None] == a).all(-1).any(-1))[0]
array([0, 1, 5], dtype=int64) # -- 0 and 5 are the start and end point of `b`
Of course, with numpy, this can be scaled up to determine adjacency amongst more than two polygons. But the simplicity of array `broadcasting` is nice.
