Zoom/Pan function in python addin tool
4241
03-20-2016 09:59 PM
Akhilkumar1
I have created one python addin tool which creates some points along a line, it works good.
my problem is when my tool gets activated i am not able able to zoom/pan the map. map view just get stuck wherever it was before clicking on that tool.
more elaborately when i am in the middle of creating a line map view get stuck.
using below code:
class PointAddressCreateClass(object):
"""Implementation for PointAddressCreate_addin.tool (Tool)"""
def __init__(self):
  self
.enabled = True
  self
.shape = "Line" # Can set to "Line", "Circle" or "Rectangle" for interactive shape drawing and to activate the onLine/Polygon/Circle event sinks.
def onMouseDown(self, x, y, button, shift):
pass
def onMouseDownMap(self, x, y, button, shift):
pass
def onMouseUp(self, x, y, button, shift):
pass
def onMouseUpMap(self, x, y, button, shift):
pass
def onMouseMove(self, x, y, button, shift):
pass
def onMouseMoveMap(self, x, y, button, shift):
pass
def onDblClick(self):
pass
def onKeyDown(self, keycode, shift):
pass
def onKeyUp(self, keycode, shift):
pass
def deactivate(self):
pass
def onCircle(self, circle_geometry):
pass
def onLine(self, line_geometry):
***Some Code HERE****
its main functionality lies in "def onLine(self, line_geometry)" function. so when i click on the map and start to create a line on map, i want zoom/pan functionality at that time.
i guess there should be a function to zoom/pan in active view by either mouse scrolling or may be any other method
WesMiller
Are you in an edit session have you tried using shortcut keys Keyboard shortcuts in ArcMap—Help | ArcGIS for Desktop
Akhilkumar1
tool does not start edit session. it based on drawn line in map it creates points along line.
and i have tried short cut keys its not working
