Python Addin - Add Layer While in Layout View
7592
10
04-26-2016 12:39 AM
TrilliumLevine1
Hello All,
I've developed a python addin toolbar that adds a desired layer file (chosen from a menu in the toolbar) to the table of contents in a project.  The functionality only works, however, when the project is in the data frame view -- clicking a layer in the menu does nothing if the project is in the layout view.  I've googled around, but haven't found a sollution to this issue.  Anyone have any ideas?  Feedback is greatly appreciated!
Using: ArcGIS 10.2.2, Python 2.7
Sample code:
# -*- coding: utf-8 -*-
import arcpy
import pythonaddins
class FD_Bau_Fischaufstiege(object):
    """Implementation for Themenmanager_addin.button (Button)"""
    def __init__(self):
        self.enabled = True
##        self.checked = False
        self.mxd = arcpy.mapping.MapDocument('current')
    def onClick(self):
        layer = r'G:\Gis\DATEN\wvdat\Querbauwerke\Fischaufstieg.lyr'
        activeDataFrame = self.mxd.activeView
        df = arcpy.mapping.ListDataFrames(self.mxd, activeDataFrame)[0]
        if arcpy.Exists(layer):
            layerToAdd = arcpy.mapping.Layer(layer)
            arcpy.mapping.AddLayer(df, layerToAdd, 'TOP')
        else:
            warningButton = pythonaddins.MessageBox("Die Datei ist nicht verfugbar.\nBitte kontaktieren Sie die GIS Abteilung.", "Datei nicht verfugbar", 0)
        pass
EDIT: I was able to get this to work in both views with the following code:
    def __init__(self):
        self.enabled = True
    def onClick(self):
        mxd = arcpy.mapping.MapDocument("CURRENT")
        df = mxd.activeDataFrame
        else:
        pass
DanPatterson_Retired
MapDocument—Help | ArcGIS for Desktop and its
activeView (Read and Write) property is the only way to set/get a layout as the active doc that I can see
TrilliumLevine1
I also tried this, but it doesn't work either:
import arcpy
import pythonaddins
class ButtonClass1(object):
    """Implementation for TEST_addin.button (Button)"""
    def __init__(self):
        self.enabled = True
    def onClick(self):
        if activeDataFrame == 'PAGE_LAYOUT':
            else:
        else:
            else:
        pass
WesMiller
You could add an extension to your tool that you could make the tool inactive in layout view.
Creating a Python add-in application extension—Help | ArcGIS for Desktop
there was a recommendation here about where to associate the mxd variable arcpy - Arcgis 10.2.2 Python Addin - Add Layer to Layout View? - Geographic Information Systems Stac...  but it went unanswered as well
TrilliumLevine1
yeah, I posted this on stack overflow as well.
disabling the toolbar in layout view is plan b, but that seems like it should be unnecessary...after all, you can add data with the 'Add Data' button while in layout view, so why wouldn't a custom toolbar with the same functionality work?  seems like an oversight on ESRI's part.
TrilliumLevine1
just tried the extension to disable the toolbar in layout view, and that doesn't work either.
Code:
import arcpy
import pythonaddins
class FishButton(object):
    """Implementation for WTF_addin.fish_button (Button)"""
    def __init__(self):
        self.enabled = True
    def onClick(self):
##        layer = r'\\msds.wv.de\dfsroot\HV\GROUP\Gis\DATEN\wvdat\Querbauwerke\Fischaufstieg.lyr'
        else:
        pass
class changeToolState(object):
    """Implementation for WTF_addin.disable (Extension)"""
    def __init__(self):
        # For performance considerations, please remove all unused methods in this class.
        self.enabled = True
    def activeViewChanged(self):
            active_view = mxd.activeView
            if active_view == 'PAGE_LAYOUT':
                WTF_toolbar.enabled = False
                print 'button has been disabled...'
            else:
                WTF_toolbar.enabled = True
                print 'button re-enabled...'
            arcpy.RefreshActiveView()
            return
And the corresponding config.xml:
<ESRI.Configuration xmlns="http://schemas.esri.com/Desktop/AddIns" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"><Name>WTF</Name><AddInID>{8ed28a7b-5aa3-4474-baa5-7674acbb350a}</AddInID><Description>New Addin</Description><Version>0.1</Version><Image /><Author>Untitled</Author><Company>Untitled</Company><Date>04/27/2016</Date><Targets><Target name="Desktop" version="10.2" /></Targets><AddIn language="PYTHON" library="WTF_addin.py" namespace="WTF_addin"><ArcMap>
    <Commands>
        <Button caption="Fish" category="WTF" class="FishButton" id="WTF_addin.fish_button" image="" message="" tip=""><Help heading="" /></Button>
        </Commands>
    <Extensions>
        <Extension autoLoad="true" category="WTF" class="changeToolState" description="" id="WTF_addin.disable" name="Disable" productName="Disable" showInExtensionDialog="true" />
        </Extensions>
    <Toolbars>
        <Toolbar caption="WTF_Toolbar" category="WTF" id="WTF_addin.WTF_toolbar" showInitially="true"><Items><Menu refID="WTF_addin.cat_menu" /></Items></Toolbar>
        </Toolbars>
    <Menus>
        <Menu caption="Category" category="WTF" id="WTF_addin.cat_menu" isRootMenu="false" isShortcutMenu="false" separator="false"><Items><Button refID="WTF_addin.fish_button" /></Items></Menu>
        </Menus>
    </ArcMap></AddIn></ESRI.Configuration>
WesMiller
You have to turn the extension on just like na or sa
TrilliumLevine1
Ah, did not know that, thanks.  Now I'm getting an error in the python window:
So...where (and how) should I define WTF_toolbar?
WesMiller
Have you tried using disabling the menu instead of the toolbar?
