Python Add In for abandoned feature class
3173
6
05-25-2018 01:11 AM
JAY_PRAKASHKUMAR
Hey everyone!
I want to create a Python Add-In tool that will perform the following sequence of tasks:
1. Read a specific feature layer in Table of Content (let's call it X)
2. Check the version for the layer [Working on SDE only]
3. Read the selected features from the layer X
4. Copy the selected features from layer X to another layer Abandoned_X and delete them from X.
5. Search layers (say Y, Z, ...) related to layer X, copy the related features to layers Abandoned_Y, Abandoned_Z, ... and delete them from Y, Z, ...
Requirements:
  • The tool should work as an extension of the editor Toolbar
  • The python Add-In button should be greyed-out when not in use and usable only after editing is turned on
  • If the edits are not saved, then the tool should revert back all the changes made to say, X, Y, Z, ...
I have written logic until step 5. Following are the questions:
  1. How to grey-out the Add-in (render is useless) when ArcMap starts?
Thank you for your time!
JAY_PRAKASHKUMAR
Hi Dan,
I was able to complete my requirement.
The below link helped me to solve my issue when I tried my add In creation freshly
Checking via ArcPy if ArcMap is in edit session? - Geographic Information Systems Stack Exchange
Thanks for your time
Jay
DanPatterson_Retired
which proposed solution?
did it just not work? or did you get errors?
JAY_PRAKASHKUMAR
Hello Dan,
I am adding the code from the link:
The part of the code I am trying to implement
class Active_Edit_Session(object):"""Implementation for NEZ_EDITS_addin.Listen_for_Edit_Session (Extension)"""def __init__(self):    self.enabled = Truedef onStartEditing(self):    button_3100.enabled=True    def onStopEditing(self, save_changes):    button_3100.enabled=Falseclass LFM_3100(object):    """Implementation for LFM_3100.button_3100 (Button)"""    def __init__(self):        self.enabled = False        self.checked = False    def onClick(self):        ......
This does not help me to gray out the python addin button with start of arcmap(it am not getting any error, It just simply do not work)
But I am able to gary out onces the editor is started and stoped.
Even I have tried
startup(self) function from below link
Extension class—Help | ArcGIS Desktop
where I kept
startup(self)
button. enable = False
does not work for me
Jay
you did edit the code you were trying to follow?  button_3100.enabled=True obviously isn't in yours
JAY_PRAKASHKUMAR
yes edited as per my requirement
   button.enabled = True
   button.enabled = False
JAY_PRAKASHKUMAR
I have just taken the concept.
The above logic works fine once the editor is started. The button does not gray out with the start of ArcMap.
JAY_PRAKASHKUMAR
Hi Dan,
Jay
