Updating datasets with Publish Routing Services utility
440
12-03-2020 12:10 AM
ShaharLevenson
New Contributor III
Hello All,
I used the Publish Routing Services utility successfully with my own network data. The routing utilities were configured and everything is working as it should.
I want to understand what is the process for updating the network dataset: should I simply re-run the tool against the updated dataset? Should the updated dataset have the same name?
I'm also interested in publishing a second network dataset with different data. Will running this tool with the second dataset generate another set of routing utilities or will everything be overwritten?
I am using the ArcGIS Enterprise 10.8.1, configured as a single machine setup.
Shahar.
