I'm trying to save a service draft to fix another issue, but when I close the Service Editor it does not prompt me with the option to save a draft like it should. As far as I can tell, there is no other way to save a service draft and that's problematic. I'm on ArcMap 10.7. Current workflow I'm following:
1) Run script tool, process succeeds
2) Share as geoprocessing service
3) Overwrite existing service
4) Service Editor opens > Analyze
5) Errors appear. Click the "x" on the service editor window to exit
Here is where no prompt to save the service draft appears. Is there somewhere I can find the service draft in windows explorer?
Solved! Go to Solution.
Found out it's saving a service draft anyway despite getting no option to save. Service drafts are located here:
C:\Users\<user name>\AppData\Local\ESRI\Desktop<version number>\Staging
