What ArcGIS Server Utility & System Services can be stopped?
446
02-10-2026 04:47 PM
StaceMaples
I have a multi-machine geocoding server setup with 5 ArcGIS Servers and a Web Adapter (linux machines). The server will only be running geocoding services. My question is whether disabling any of the Utility/system services that are running by default can improve performance? If so, what services are not used in geocoding (batch, reverse, suggestion). I can't find this documented, anywhere.
Thanks!
Stace
GlenterpriseUK
Hi @StaceMaples,
I hope you are well.
There isn’t any documentation that I am aware of, that says turning off system or utility services will boost geocoding performance. In practice, the built‑in system services hardly use any resources when they’re idle, so shutting them down usually doesn’t have any real impact on overall performance.
Regards,
Glen
