Sharing layer to Everyone
1685
11-17-2020 07:43 AM
SteveWalker2
I have added over 175 layers to our Open Data Portal, and ONE keeps locking up
when trying to Share to Everyone. Not sure- I have tried everything from renaming, re-projecting,
and loading from a different server. Any suggestions?
Travis_Esri
Hello,
When adding it as an item (and publishing as a hosted feature layer) I was also unable to share the layer with everyone (nor was it displaying in any map viewer). However, when I added the item to a new project and published it as a hosted feature layer, I was able to successfully view it and share with everyone. Maybe it has to do with how you are adding the item? Are you just adding it as an item straight to your portal? Maybe publishing can be a viable workaround?
Using Enterprise 10.8.1 with latest version of Pro.
Travis
SteveWalker2
Thanks. I am adding to a portal. Working with an ESRI tech support, he thinks it is something weird with
the shapefile. I'll update when he gets back to me.
