Publishing Vecor tile maps
1978
11-07-2023 01:39 AM
ADITYAKUMAR1
Hi ,
  I have published Vector tiles map using ArcGIS Pro. The vector tile services has been found under hosted tab in ArcGIS Server rest url.  But when I compare the vector tile with the basemap service of ArcGIS, the content is entirely different.  For https://basemaps.arcgis.com/arcgis/rest/services/World_Basemap_v2/VectorTileServer I get the json details
But in my local enterprise I get a different result.
Thanks
Aditya
Tags (1)
A_Wyn_Jones
Hi @ADITYAKUMAR1,
You can add ?f=json into the URL to get the same output or click the JSON button which is just under "Home" in your second screenshot.
A
"We've boosted the Anti-Mass Spectrometer to 105 percent. Bit of a gamble, but we need the extra resolution."
A_Wyn_Jones
Hi @ADITYAKUMAR1,
A
ADITYAKUMAR1
@A_Wyn_Jones Thanks for the response.
   As suggested I have added it and its showing the result. But I am confused why the URL from ESRI is showing the same without putting ?JSON while I explicitly need to add JSON parameter?
Thanks
Aditya Kumar
A_Wyn_Jones
@ADITYAKUMAR1 No problem.
I believe Esri has customised their endpoints to prevent casual browsing of their services.
Another example is that the services rest endpoint is restricted here: https://basemaps.arcgis.com/arcgis/rest/services
For further context, this aligns with best practice for ArcGIS Server. Please look at SS07 here:
https://enterprise.arcgis.com/en/server/latest/administer/windows/scan-arcgis-server-for-security-be...
