Creating and Publishing a Database View from a table containing lat/long coordinates
2552
11-08-2023 07:56 AM
DavidEvans5
Hi There,
I am trying to create a Database View from a table that contains data extracted from our utility billing software with latitude and longitude coordinates for each account. I'm very new to this and I'm relying on an example view I found in an ESRI Community posting here which I've modified by adding a "Select" statement to try to make it include a some of attribute data from the table (ServiceLocation, CurrentAccount etc.).
The view works in to extent that the locations are plotting correctly based on the lat/long coordinates, but  when I attempt to view the attribute table I get a "Failed to retrieve a page of rows" error.
CREATE VIEW VIPCustomerPointsView
AS
SELECT  ServiceLocation, CurrentAccount, ServiceLocationOid, AccountNumber, AccountOid, StartDate, LocationId, GISId, ServiceLatitude, ServiceLongitude, ServiceStreetNumber, ServiceStreetName, ServiceStreetSuffix, ServiceCity, ServiceZipcode
geography::Point(CASE ISNULL(ServiceLatitude,0)
WHEN 0 THEN '37.809737'
ELSE ServiceLatitude END,
CASE ISNULL(ServiceLongitude,0)
WHEN 0 THEN '-85.509352'
ELSE ServiceLongitude END
, 4326)  AS GeomPoint
FROM DBO.dbo_IdsForGISFinalCable1
I'm guessing that I've used the wrong syntax with my select statement or missed something somewhere and that's preventing the View from fetching all the attribute data. If anyone can help by showing me the correct script I should use you all have my sincere appreciation.
Thanks!!
MarceloMarques
if you are using an enterprise geodatabase, then read below.
Views in an enterprise geodatabase—ArcGIS Pro | Documentation
Create Database View (Data Management)—ArcGIS Pro | Documentation
Query layers—ArcGIS Pro | Documentation
| Marcelo Marques | Esri Principal Product Engineer | Cloud & Database Administrator | OCP - Oracle Database Certified Professional | "About: In 1992, I embarked on my journey with Esri Technology, and since 1997, I have been working with ArcSDE Geodatabases, right from its initial release. Over the past 33 years, my passion for Spatial Databases and GIS data has become a central part of my career.." | “ The mountains are calling and I must go.” – John Muir |
DavidEvans5
Thankyou Marcelo, We are using an enterprise geodatabase, yes.
I read through the documentation but I didn't really find out what I needed to about the scripting of the View Definition. Sample code, if anyone can provide it, would really help out here.
