Publishing a layer that requires access to a different database
1719
07-03-2024 07:14 AM
Joey_NL
Hi there,
We have a database which only the ArcGIS enterprise server can connect to, it's not accessible from the user's PC. Similar to the situation described here.
Publishing a hosted layer fails because at staging and publishing it fails to make a connection. The connection is however correctly registered to the enterprise server data store.
We have a workaround to publish from a VM which is permitted to make a connection to the database. Is it possible to reference a saved data store on the server without having to make connection to it from ArcGIS Pro?
This would be possible if the data was in a file geodatabase and you could see that through the 'Replaced' tab in Service Workspace
Giving access to the database from a users' PC is not possible. As far as I can see, updating this through CIM is only possible once it's been published, and would still fail from a user's PC instead of the VM.
Thanks in advance!
MarceloMarques
@Joey_NL
Question:
Answer: as you described the machine running ArcGIS Pro needs to be able to connect to the database, then the layers are added to the map in Pro, and then Pro can publish the service to ArcGIS Server.
If the machine running ArcGIS Pro cannot connect to the database, then the workaround for this situation is to publish the service via ArcGIS Server Manager, see link below for more information.
Publish services using Server Manager—ArcGIS Server | Documentation for ArcGIS Enterprise
I hope this helps.
| Marcelo Marques | Esri Principal Product Engineer | Cloud & Database Administrator | OCP - Oracle Database Certified Professional | "About: In 1992, I embarked on my journey with Esri Technology, and since 1997, I have been working with ArcSDE Geodatabases, right from its initial release. Over the past 33 years, my passion for Spatial Databases and GIS data has become a central part of my career.." | “ The mountains are calling and I must go.” – John Muir |
MarceloMarques
@Joey_NL
Question:
I hope this helps.
Joey_NL
Hey @MarceloMarques ,
Thanks so much for your reply, completely agree with you, however the StageService function fails because the database isn't accessible and so it's not possible to generate an *.sd file.
When calling MapServiceDraft we are setting offline: True and the *.mapx file connects to a valid shadow database.
I read that it is possible to create a connection-neutral *.sd using 'No available connection' when working in different environments but I can't see any way to do this in CreateSharingDraft or StageService.
Is there something here I'm missing? Let me know if I can share anything to help expand further.
MarceloMarques
@Joey_NL - Indeed, it will fail if the machine that you are using cannot connect to the database, see if you can use a machine that can connect to the database, otherwise I am not aware of any other workaround. You can open a ticket with Esri Technical Support to ask if there are any other workarounds for your situation.
Joey_NL
Just to add to the message above, have also ensured that the data sources are registered on ArcGIS Server (11.2) with the publisher and server database connections.
