Published Web Tools Not Displaying Messages in Geoprocessing Window
1762
06-28-2022 10:34 AM
by Anonymous User
Not applicable
Hey all,
So I have published a web tool using ArcGIS Pro 2.9.2 and am running into some annoying issues trying to use it.
To create the web tool, I wrote a python program in Jupyter Notebook, then exported the program to a standard python script (*.py), tested it and confirmed that it worked. Add the script as a tool in my local toolbox, tested the script to confirm that it worked (it did), and then I published the tool as a web tool to my ArcGIS Enterprise Portal.
This is where things went sideways.
So random issues with my script notwithstanding, I am trying to add messages into my code that can display in the geoprocessing window. I used the code snippet: arcpy.AddMessage("Text here.") all throughout my code, but they will not display in my geoprocessing window.
Furthermore, I tested a separate program that did almost nothing but give me messages, here is that program:
import arcpy
arcpy.AddMessage("Starting to run the tool")
gdbPath = arcpy.GetParameterAsText(0)
arcpy.AddMessage("Input file is: " + gdbPath)
wksp = arcpy.env.workspace = gdbPath
arcpy.AddMessage("The workspace for the project is: " + wksp)
arcpy.AddMessage("Hello? Is anybody out there?")
and so on. The thing is, this works perfectly on my local machine. The second I publish it as a web tool, it displays none of the messages.
Please help.
Edit: Our Portal is currently 10.8.1
Tags (3)
BE4
Running into the same hurdle here. ArcPro version 3.03 and portal 10.9.1.
