Published Elevation Layer does not cointain elevation data
1351
01-07-2021 05:14 AM
by Anonymous User
Not applicable
Hello everybody,
I have some problems publishing an Elevation Layer to an Enterprise Portal. I have a .tif containing elevation data which I added as an elevation source in an ArcGIS Pro Scene. In ArcGIS Pro the data is displayed correctly.
When publishing the data as a Web Layer the process itself works and an Elevation Layer is published, but when looking at it in the Scene Viewer the Layer does not contain Elevation Data.
I tried several things, like referenced vs. registered data, different tiling schemes, ocal vs. global scene etc. but none of it worked. Since there is no error whatsoever I do not have an idea where to start looking.
Has anyone encountered a similar problem? I am happy for all suggestions. Thanks.
by Anonymous User
Not applicable
Hi Alexander,
Do you have an ArcGIS Server site with the Image Server role? In order to publish raster elevation surfaces, this is a requirement: https://www.esri.com/content/dam/esrisites/en-us/media/brochures/arcgis-enterprise-functionality-mat...
-Calvin
