Newly added layers missing from Feature Service
2409
10-31-2024 04:58 AM
Anne_Tetley
Not sure when this started, possibly since our move to Enterprise 11.3 in September but might predate that slightly..  we're seeing issues where we add new layers to an existing map service document in Pro and overwrite the service, the new layers appear in the Map Service but are missing from the Feature Service.  We remedy it by republishing without the feature service capability ticked, then republish with the feature service ticked.  This finally brings the layers into the feature service.
We're getting errors in the logs "Failed to Update Service Item Data Json file to Portal."
Just wondered if anyone else was seeing this and if its a known bug?
Marc_Graham
Hi there, we are seeing this error in our ArcGIS Server logs sometimes when publishing hosted feature services.  Also post an upgrade, 10.9.1-11.3. Would love to know how to fix it.
JesseCloutier
Esri Community Manager
Hi @Anne_Tetley and @Marc_Graham, we appreciate you sharing a potential bug with the broader Esri Community; however, Esri does not actively track software defects posted here. The official channel for investigating and validating bugs is Esri Technical Support. All customers experiencing a potential software bug should leverage technical support to report and investigate the issue.
By reporting bugs through technical support, Esri can better track the scope and impact of the issue across all our customers and better prioritize it with our product teams. Our teams can also investigate the issue more thoroughly to see if there is a solution, workaround, or patch to get you back up and running as soon as possible.
As a reminder, Esri Community is primarily a self-service support platform where Esri users can ask or answer each other’s questions, share feature requests, and collaborate to solve problems with GIS.
*Note that this is a scripted message prompted when posts allude to a potential product bug.
Jesse Cloutier
Community Manager, Engagement & Content
jorisfrenkel
Just FYI, this error message: "Failed to Update Service Item Data Json file to Portal." popped up recently in our log in Enterprise 11.5, when overwriting a referenced web layer from ArcGIS Pro.
According to information on the Esri website it's a bug that was resolved in a previous version.
So it looks like the bug has returned.
If time allows I will submit this with ESRI support.
