Generate an 'exploded' cached map service in ArcGIS PRO (Enterprise 10.8.1)
2089
08-30-2022 11:39 PM
CoMAGOL_ADMINISTRATOR
I'm trying to generate a map service with an Exploded cached map service using ArcGIS PRO 2.8 into ArcGIS Enterprise 10.8.1
I've used the 'Generate Tile Cache Tiling Scheme' geoprocessing tool to create the attached file.
I've then published the service referencing the file but the format type within ArcGIS Server is still set to 'Compact'.
Anybody have any ideas?
NicolasGIS
Honored Contributor
I think this property is only available at ArcGIS Server Manager interface in the cache properties:
So I guess the workflow would be the following:
1. Publish service and configure the cache to be generated manually afterward
2. Modify cache storage to "exploded" in ArcGIS Manager
3. Generate cache
To be tested though !
Hope that help
