ESRI OID of service isn't synced between two machines of server
685
01-08-2025 02:19 AM
ValentinH
I'm having issues with an arcgis server composed of two machines. Services published on those (postgres query layers) get an added "ESRI_OID" despite having an id field built-in selected at their creation in Arcgis Pro.
This would be somewhat acceptable if not weird but these dont seemed to "sync" between sites as depending on which machine is responding the id for the same object won't be the same.
Having apps relying on ids for requests makes them crash as on request send an id that won't exist in the next request.
So I was wondering if there was a way to sync them up or maybe use the original id of the data instead of having arcrgis pro/arcgis server create one?
thank you
