I am attempting to trouble shoot an error when attempting to publish a Hosted Feature Service from ArcPro. I have an open ticket with ESRI Support, but are not yet able to determine why.
Here are some of the things we have already attempted:
Attempted to Publish in ArcPro 2.9.5 and ArcMap 10.8 neither worked. Working with Enterprise 10.9.
Any help is appreciated
Hello @amarcz_cc ,
This is an interesting error and even after you have performed a lot of steps it has remained then it could be something intricate which is causing the communication of components involved to break.
As per my understanding, if this allows you to publish from registered data sources then ArcGIS Server is working perfectly fine. That leaves two other components i.e. Portal for ArcGIS and ArcGIS DataStore which are to involved in this publishing process. Hence, I would like to take an approach on them. In order to understand that these components are working fine, if possible can you try the following and share the results
For ArcGIS DataStore:
For Portal for ArcGIS:
Furthermore, if these does not shed some insight, I found few more articles which corelates to the problem you are encountering (some you may have already performed from these):
If none of the above helps to narrow down, try switching the ArcGIS Server log level to "DEBUG" (Please be aware that these are detailed logs and cause increased disk consumption. It's recommended that you don't use this level in a production environment; it may cause a decrease in performance.) and share them here for me to have a look.
Hopefully one of these would allow you to narrow down the cause and then a feasible solution.
Hope above helps!
Archit
Thanks for the ideas Archit, I have attempted the steps you have described with an ESRI Support tech and have yet to find a solution to the problem. I am actually upgrading from an Enterprise Standard Agreement to an Enterprise License Agreement, and once that is completed I will come back to this problem.
Did you ever find a solution for this issue? we are encountering the same error on our end and would like to know if you did.
The error was a much larger problem than anticipated that actually required a full re-instillation from scratch of a whole new Enterprise. But something that did work for us was to go into the Server Machine and re-configure the 'Configure ArcGIS Server Account' tool
