Domain disappear in Map Service
1266
01-02-2025 02:13 AM
User35488
Hi There,
All the domains of a layer let's say 'Layer B' disappear in the map service after publishing, if any other layer, let's say 'Layer A' with 100 subtypes uses a domain(this domain is different than the domain of Layer B) more than 31 times.
When I reduce the domain usage to 31 or less times, and republish, the domain for the layer B appears.
The domain works fine in ArcGIS Pro, in all cases.
Appreciate your thoughts on it.
Environment: ArcGIS Enterprise 11.3, ArcGIS Pro 3.2, Oracle, Geodatabase 11.2
TanuHoque
@User35488
pls try bumping up the value for 'Maximum number of coded domains' for your map service from the Manager site.
TanuHoque
@User35488
User35488
Thanks @TanuHoque
It's working perfectly fine.
