A hosted feature layer in our organisation's ArcGIS Enterprise became completely corrupted following an attempt to overwrite it. I am now trying to delete it, however it is 'delete protected' and I cannot access the layer's settings page at all (see screenshot) to disable the deletion protection and delete it from there, as I just get a continuous "Loading..." screen. Is there a workaround in the backend or otherwise to delete it?
Hi @Woosh_AP
Hi @Woosh_AP
Thanks @Priya_Das . The first link seems to partially work. The problematic feature layer then persisted on Enterprise in the content menu. I then had to redo the same for all view layers and then reindex the content.
Thanks for your solution.
