Cannot invoke "com.esri.standardsql.query.Selection.getExpression()" because "<local6>.y" is null
7533
16
08-01-2024 07:39 AM
NoahFrazzini
Following an upgrade from 11.1 to 11.3, our hosting server started throwing these errors.
Type: Severe
Message: "feature server..." Cannot invoke "com.esri.standardsql.query.Selection.getExpression()" because "<local6>.y" is null
Target: Rest
Machine: Hosting Server
Code: 9000 (Cannot access Admin API)
-- I am pulling these errors from the Admin API
Process: 11868.
I am unsure as to why this has started so any advice or insight would be greatly appreciated. All enterprise datastores are healthy and validated. This specifically started happening following the upgrade and have not seen any other documentation on the matter. Due to privacy concerns I cannot provide screenshots.
NoahFrazzini
There is another error code that the admin logs show.
Type: Warning
Message: Request for service'...' did not have adequate credentials
Target: Admin
Code: 7331
Process: 11868
JustinMallinckrodt
Hello Noah - Sorry to hear about your recent experience after upgrading to 11.3.
Can you share more information about other symptoms that are happening?
- Is there a consistent time these errors are showing up? How frequently? What is the action that's occurring?
- What type of authentication are you using?
As you mentioned, getting this error while being able to access the Admin API seems strange.
NoahFrazzini
The errors are constant and they pretty much fill the whole log on a daily basis. The action is usually a user attempting to host a service on the portal whether that be updating information or posting new features. And we are using IWA.
Joshua-Young
MVP Regular Contributor
Does Esri have a fix for "Cannot invoke "com.esri.standardsql.query.Selection.getExpression()" because "<local6>.y" is null"?
We are on ArcGIS Enterprise 11.5 and are still seeing this error in the ArcGIS Server logs. It seems to only happen to hosted feature services and right now I am seeing getting the error while using some hosted feature services in a web scene. We are not getting errors for not adequate credentials.
"Not all those who wander are lost" ~ Tolkien
LanceKirby2
I'm getting a similar error after migrating my 11.3 portal to a new machine. Have you come across a cause of this issue?
JakeNeedle
I am getting the same error in my 11.3 server logs also " Cannot invoke "com.esri.standardsql.query.Selection.getExpression()" because "<local6>.y" is null".  It appears mostly to be occurring on Hosted layers.
Any body have any solutions on this?
Marc_Graham
Hi, we just upgraded from 10.9.1 to 11.3 and are also seeing our logs flooded with this error
johnjcarter
Also found this error on a number of hosted logs with ArcGIS Enterprise 11.3 running on Azure "Hosted/Service_Name/FeatureServer: Cannot invoke "com.esri.standardsql.query.Selection.getExpression()" because "<local6>.y" is null"
BillMoody
Same error here too.  Just upgraded to 11.4 from 10.9.1.
