Error when running BetterBusBuffers "Count Trips on Lines" tool
1657
08-11-2020 08:50 AM
DavidPerlmutter
After running the "Count Trips on Lines" tool of the BetterBusBuffers toolbox, I encounter the following error after running step 2, "count trips on lines:"
"There is no transit service during this time window. No service_ids cover the weekday or specific date you have selected."
On further inspection of the GTFS package's calendar.txt file, I find that every one of the [day of week] fields is entered as zero, which seems unusual. Original GTFS package is attached.
Any ideas for a workaround?
Tags (1)
MelindaMorang
It looks like this agency just decided to explicitly turn on service using the calendar_dates.txt file for specific dates rather than including a regular service defined in calendar.txt.  To successfully run the BetterBusBuffers tools, you should use a specific YYYYMMDD date for the input date instead of a weekday.
MelindaMorang
DavidPerlmutter
Thank you, Melinda! This seems to have fixed the problem.
