assistance with exercises
2697
12-31-2012 01:34 PM
ErikRau
Good day from a new MapSAR student in Oregon. I'm guessing this is will be an ignominious entry into the forum, as I have what is probably a trivial question.
As I work through the exercises provided on mapsar.net, I have run into a repeated problem with the first task in Chapter 8 (on page 177 of Using GIS for Wildland...). I edited the attribute table for 'Operation_Periods,' but left the '@#Period*' and 'End Date/Time' columns blank, stopped editing and saved edits, and was able to Update_Domains successfully, but the aforementioned values remained <Null>, and didn't auto-populate. If I go back and manually add values to either of those columns, I get the following error:
Executing: Model42
Start Time: Mon Dec 31 15:10:27 2012
Executing (Table To Domain): TableToDomain C:\MapSAR\20120508_Pinecrest_Search_Danny_UTM11\SAR_Default.gdb\Search_Segments Area_Name Area_Name C:\MapSAR\20120508_Pinecrest_Search_Danny_UTM11\SAR_Default.gdb Areas Areas REPLACE
Start Time: Mon Dec 31 15:10:28 2012
Succeeded at Mon Dec 31 15:10:28 2012 (Elapsed Time: 0.00 seconds)
Executing (Table To Domain (3)): TableToDomain C:\MapSAR\20120508_Pinecrest_Search_Danny_UTM11\SAR_Default.gdb\Teams Team_Name Team_Name C:\MapSAR\20120508_Pinecrest_Search_Danny_UTM11\SAR_Default.gdb Teams Teams REPLACE
Succeeded at Mon Dec 31 15:10:29 2012 (Elapsed Time: 1.00 seconds)
Executing (Table To Domain (4)): TableToDomain C:\MapSAR\20120508_Pinecrest_Search_Danny_UTM11\SAR_Default.gdb\Incident\Operation_Period Period PeriodText C:\MapSAR\20120508_Pinecrest_Search_Danny_UTM11\SAR_Default.gdb Period PeriodText REPLACE
Start Time: Mon Dec 31 15:10:29 2012
ERROR 999999: Error executing function.
The name of an entry in the CodedValueDomain is empty.
The name of an entry in the CodedValueDomain is empty. [domain name: Period]
Failed to execute (Table To Domain (4)).
Failed at Mon Dec 31 15:10:29 2012 (Elapsed Time: 0.00 seconds)
Failed to execute (Model42).
Failed at Mon Dec 31 15:10:29 2012 (Elapsed Time: 2.00 seconds)
I tried trashing the entire exercise directory and re-downloading, but encountered the same problem. Suggestions?
I'm running ArcMap 10.0 in Win7, and have generally had good functionality (except the occaisional lag due to a non-optimized laptop).
ArnoldGaffrey
Hi Erik,
If what Vanessa suggested doesn't work, you can view all the fields in the Attribute Table to find out which one is not populating.  Do this by:
Opening the Operations_Period Attribute Table
Click on Table Options, located in the upper right corner of the table
Click on Restore Defalut Field Order.
This will display all the hidden fields in the table.  At this point you will be able to complete any empty fields.
Thanks for trying MapSAR.
Arnold
ErikRau
Many thanks to you both for your prompt replies, and apologies that I didn't seem to stay engaged. In reality, I've been fighting to get back to working on this, as I really enjoy fiddling with MapSAR, but am sadly lacking in technical expertise.
At any rate, I tried both of your solutions, in order, and it didn't solve the problem. I plowed ahead to the next series, however, but am still getting the following error message when updating domains:
Executing: Model42
Start Time: Wed Jan 23 17:42:39 2013
Executing (Table To Domain): TableToDomain C:\MapSAR\8_mapsar_ex_data_final\20120508_Pinecrest_Search_Danny_UTM11\SAR_Default.gdb\Search_Segments Area_Name Area_Name C:\MapSAR\8_mapsar_ex_data_final\20120508_Pinecrest_Search_Danny_UTM11\SAR_Default.gdb Areas Areas REPLACE
Start Time: Wed Jan 23 17:42:40 2013
Succeeded at Wed Jan 23 17:42:41 2013 (Elapsed Time: 1.00 seconds)
Executing (Table To Domain (3)): TableToDomain C:\MapSAR\8_mapsar_ex_data_final\20120508_Pinecrest_Search_Danny_UTM11\SAR_Default.gdb\Teams Team_Name Team_Name C:\MapSAR\8_mapsar_ex_data_final\20120508_Pinecrest_Search_Danny_UTM11\SAR_Default.gdb Teams Teams REPLACE
Start Time: Wed Jan 23 17:42:41 2013
Succeeded at Wed Jan 23 17:42:41 2013 (Elapsed Time: 0.00 seconds)
Executing (Table To Domain (4)): TableToDomain C:\MapSAR\8_mapsar_ex_data_final\20120508_Pinecrest_Search_Danny_UTM11\SAR_Default.gdb\Incident\Operation_Period Period PeriodText C:\MapSAR\8_mapsar_ex_data_final\20120508_Pinecrest_Search_Danny_UTM11\SAR_Default.gdb Period PeriodText REPLACE
Failed at Wed Jan 23 17:42:41 2013 (Elapsed Time: 0.00 seconds)
Failed at Wed Jan 23 17:42:41 2013 (Elapsed Time: 2.00 seconds)
This despite the attribute table for Operation_Periods looking like the attached:
[ATTACH=CONFIG]21020[/ATTACH]
