ArcGIS Equivalency Update for Oriented Imagery Classic
1233
12-22-2025 08:39 AM
EmilyWindahl
As 2025 comes to a close, it’s a good time to take stock of the progress we’ve made integrating functionality from Oriented Imagery Classic directly into ArcGIS.
Oriented Imagery Classic was deprecated in January 2025 and will be retired in 2026. The new integrated version of oriented imagery uses similar patterns, but has been built into ArcGIS from the ground up, with a new data model, management tools, and viewer.
The oriented imagery features now available in ArcGIS are rapidly approaching parity with Oriented Imagery Classic. This means most users can transition away from the older, community-supported prototype and benefit from oriented imagery functionality that’s fully embedded in ArcGIS.
Oriented imagery features available in ArcGIS today
The table below shows key features from Oriented Imagery Classic and when they became available across ArcGIS foundational products.
Features planned for 2026
A few Classic features are still in development, including:
  • A workflow for managing video using an oriented imagery dataset
  • Support for managing and visualizing 360° video
  • The oriented imagery viewer integrated into Scene Viewer
  • The ability to superimpose images in a 3D scene
We expect most users can migrate now without these features, but they are on track for release in 2026.
Classic features that won’t be supported
Some Oriented Imagery Classic features will not carry forward:
You will not be able to define custom variables as part of the oriented imagery layer schema the way you can with oriented imagery catalogs. This also means that we will not be able to support token servers, which rely on the custom variables in Oriented Imagery Classic. To securely host images, users can leverage feature attachments in ArcGIS Online or custom data feeds in ArcGIS Enterprise 11.5+. Support for secure image hosting using ArcGIS Enterprise cloud stores and ArcGIS Pro will be available in 2026.
Additionally, we do not plan to provide a separately hosted app like the Oriented Imagery Classic Explorer. Instead, users can take advantage of the built-in oriented imagery viewer in Map Viewer or ArcGIS Excalibur; build Instant Apps using the Sidebar and 3D Viewer templates; or build an Experience Builder app using the Oriented Imagery Viewer widget.
Next steps for Oriented Imagery Classic users
If you haven’t already, it’s time to familiarize yourself with the oriented imagery functionality that has been integrated into ArcGIS, and start migrating your Oriented Imagery Classic management workflows, oriented imagery catalogs, and apps.
Note: This blog was updated February 2026 to clarify timelines for depth map support across ArcGIS and for secure image hosting with ArcGIS Enterprise.
2 Comments
JamesHead-Mears1
Hi @EmilyWindahl,
The table in your post mentions that support for depth maps (.dm) have been implemented in ArcGIS Pro 3.6 and Enterprise 12.0. I've had a look around the documentation for both these versions and can only find a passing mention of depth maps in relation to accuracy but no information on how they are referenced by the OID. Should we be assuming that it is implemented in the same way that the OIC classic schema references the depth map using DepthImg (as per oriented-imagery/OrientedImageryCatalog_Schema.pdf at master · Esri/oriented-imagery)?
Cheers,
James
EmilyWindahl
Hi @JamesHead-Mears1, thank you for the question. The table in the original post was incorrect. Depth map support was introduced in ArcGIS Online with the November 2026 update and will be available in ArcGIS Pro 3.7 and ArcGIS Enterprise 12.1. I’ve updated the table in the blog to align with those releases. Apologies for the confusion, and thank you for bringing this to our attention.
Contributors
About the Author
Emily is a product manager on the Imagery Team, helping create tools and best practices for working with imagery and rasters in ArcGIS.
