Problems building 2.0.0-beta.6
5184
12-01-2015 11:35 AM
AnthonyColby1
Okay, I'm a bit new to this but I don't think I'm going wildly wrong - hopefully.
I'm looking to get Esri Leaflet to support an internal custom cached map scales and therefore am modifying the TileLayer code. I've forked and cloned a copy of the 2.0.0-beta.6 code base from Git, have made the changes I want to test, but am struggling to get the build process to work.
The process I've followed is:
  • The current user is a local administrator - PC is running Windows 10 but I've had the same issue on a Windows 7 PC.
  • I've downloaded and installed the latest versions of Node.js and GItHub Desktop.
  • I've forked and cloned the code base to my local machine and at this stage haven't made any changes to the code base (I want to make sure I can get the build process working first before making changes and running it again).
  • In GitHub Desktop I've opened a 'Git Shell' and run 'npm install', but get the following output:
C:\GitHub\esri-leaflet [master]> npm install
> [email protected] prepublish C:\GitHub\esri-leaflet
> npm run build
> [email protected] prebuild C:\GitHub\esri-leaflet
> mkdirp dist
> [email protected] build C:\GitHub\esri-leaflet
> ./scripts/build.js
'.' is not recognized as an internal or external command,
operable program or batch file.
Once the build successfully completes then I'm expecting to run 'npm run serve' and then 'npm test' - is that correct?
Any suggestions / help would be appreciated.
Thanks
Tony
JohnGravois
you're definitely on the right track.  in the package.json just replace:
"build": "./scripts/build.js",
// with
"build": "node ./scripts/build.js",
Check out the previously logged bug here for more information.
JohnGravois
// with
