leaflet wms map image
5431
10-09-2021 09:04 AM
BradSkopyk
I am new to Leaflet. I have a historical map that I have georectified and that is hosted on my arcgis server. I am including both the REST and WMS URLs:
https://elcamaleon.binghamton.edu/server/rest/services/Teo1925/MapServer
https://elcamaleon.binghamton.edu/server/services/Teo1925/MapServer/WMSServer
I would like to know which of the esri-leaflet plugins I should use: L.esri.ImageMapLayer or L.esri.DynamicMapLayer or something else. And, how would I format the html script.
Thank you for your help.
GavinRehkemper
You can use "L.tilelayer.wms" - see the tutorial on the Leaflet documentation site:
https://leafletjs.com/examples/wms/wms.html
Here's a code sample using your service:
https://jsbin.com/tuhukamefu/1/edit?html,output
BradSkopyk
I figured it out! Here is the html:
<meta charset="utf-8"><meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no" />
<title></title>
<!-- Load Leaflet from CDN -->
<link crossorigin="" href="https://unpkg.com/[email protected]/dist/leaflet.css" integrity="sha512-xodZBNTC5n17Xt2atTPuE1HxjVMSvLVW9ocqUKLsCC5CXdbqCmblAshOMAS6/keqq/sMZMZ19scR4PsZChSR7A==" rel="stylesheet" /><script src="https://unpkg.com/[email protected]/dist/leaflet.js"
integrity="sha512-XQoYMqMTK8LvdxXYG3nZ448hOEQiglfqkJs1NOQV44cWnUrBc8PkAOcXy20w0vlaXaVUearIOBhiXZ5V3ynxwA=="
crossorigin=""></script><!-- Load Esri Leaflet from CDN --><script src="https://unpkg.com/[email protected]/dist/esri-leaflet.js"></script><script src="https://unpkg.com/[email protected]/dist/esri-leaflet-vector.js"></script>
<style type="text/css">body { margin:0; padding:0; }
#map {
position: absolute;
top:0;
bottom:0;
right:0;
left:0;
font-family: Arial, Helvetica, sans-serif;
font-size: 14px;
color: #323232;
</style>
<div id="map">&nbsp;</div>
<script>
const apiKey = "Put API Key here";
var map = L.map('map').setView([19.65, -98.9], 12);
L.esri.basemapLayer('Imagery').addTo(map);
var url = 'https://elcamaleon.binghamton.edu/server/rest/services/Teo1925/MapServer';
L.esri.dynamicMapLayer({
url: url,
opacity: 0.99,
useCors: false
}).addTo(map);
</script>
BradSkopyk
So, actually, the first solution does not actually use a WMS layer. Any hints on how to show a wms map image with leaflet? If anyone is using Omeka, specifically the WMS Overlays function that is found in some of the preconfigured mapping blocks, like Map by Attachments. Here, you would configure as:
Base URL: https://elcamaleon.binghamton.edu/server/services/Teo1925/MapServer/WMSServer
Layers: 0 [i.e. zero]
GavinRehkemper
BradSkopyk
Thank you!
