Getting an error when trying to do a query in esri-leaflet
6258
17
09-12-2014 10:42 AM
joepublic
I am trying to created an app that when you click on a button at the top of the page will display only the countries that will satisfy the query attached to the button (see bottom of the file attached).
Here is the snippet of the code:
$('#NSM').click(function(){
     var buttonType = document.getElementById('NSM');
     countries.setWhere('type="'+ buttonType.value + '"');
I am using the "querying features #2" as my template.
The error I'm getting is
{"error":{"code":400,"message":"Unable to complete operation.","details":["Attribute column not found [Microsoft SQL Server Native Client 11.0: Invalid column name 'NSM'.] [MEP_global_data.DBO.test_bdry]"]}}
Any help would be appreciated
joepublic
Hmmm...
I am running it on a esri webserver installed on an AWS virtual machine.
countries.addTo(map); <- placed outside the click function
      countries.setWhere("type like "+"'"+buttonType.value+"'");
The above "works" but it creates the a layer of ALL the countries BEFORE the setWhere works
see link: Add Map
But I want to create the layer only AFTER you click on the button with the countries that satisfies the query.
Chris
PaulCrickard1
Occasional Contributor II
Don't preload the layer. Load the basemap then add the layer using the where option - NOT the setWhere() method.
var countries = new L.esri.featureLayer(featureURL,
  style: getStyle,
  onEachFeature: onEachFeature,
  where: "type like"+"'"+buttonType.value+"'"
  }).addTo(map);
If you will have lots of buttons, then make a function loadLayer() and pass the buttontype value. then you only need to add the code for the layer once.
PaulCrickard1
Loading the full layer is really slow on my machine. Preloading it is not making setWhere() and faster than if you just load the layer with where option onclick. I think loading using where is faster by a lot.
joepublic
Paul,
Your suggestions worked great!!
The new issue I have is with my mouseout:resetHighlight
resetHighlight(e){
     countries.resetStyle(e.target);
Is not recognizing the "countries" object since Iam now creating the instance inside of the click function.
PaulCrickard1
I think there is something wrong with the e.target - it is an object and you need to pass and ID to the resetStyle() method.
I added
var countries;
as the  first line after the <script> tag. Delete the var in the onclick button function.
Then where you have resetStyle(), I put this instead:
countries.setStyle(getStyle());
Works. Code is as simple as ResetStyle() because I am just recalling your original style function.
joepublic
Make countries a global variable worked
I do have multiple buttons and what to clear the countries from the
previous button click...
Any suggestions??
PaulCrickard1
Use map.removeLayer(). In each buttons function, before you add a layer, check to see if the other layers are on and turn them off if they are. then load your layer for the button.
if(map.hasLayer(countries)){
                 map.removeLayer(countries);
                 countriesABC = new L.esri.featureLayer(featureURL-ABC, { style: getStyle, onEachFeature: onEachFeature,where: "type                                              like"+"'"+buttonType.value+"'"
                                               }).addTo(map);
else {alert("aint got it");}
joepublic
Paul,
Everything looks good!!
Thanks for the help!!
Chris
