NZ Imagery Map not Updated
509
08-18-2024 01:45 PM
JeremiahGbolagun1
Hi there,
The NZ imagery map integrated in ArcGIS Pro 3.3.1 is not current. I suggest ESRI helps to resolve this problem. For instance, when I go to Map and click the Basemap and from the down menu the current NZ imagery is not updated because there are areas in Oamaru where new development have done but those features are reflected in the NZ imagery.
Can ESRI helps to resolve this issue?
Regards
cle444
It is not ESRI's responsibility to update the NZ imagery basemap. NZ basemap is not part of the ArcGIS Pro fee, and it is a free resource for users. I assume the one you are referring to is provided by Eagle Technology, i.e. https://services1.arcgisonline.co.nz/arcgis/rest/services/Imagery/newzealand/MapServer
In general, it updates when it updates. You may want to search other publicly available imagery services e.g. by local councils. The last option usually works - check out the paid services, e.g. NearMap.
