UPDATE November 23rd 2017
The Welfare Needs Advisory Group has met and decided on a common set of minimum data. We are now hosting an XLSForm schema that reflects these changes. This is likely to change in the coming months as the adivsory group and others make modifications.
Link to XLSForm: www.arcgis.com/home/item.html?id=770addcdad8641cb91fa3539c92e20dc
The below information was posted prior to the November 23rd update.
This is a XLS Form for Survey123 based on the EMIS Welfare Form. This was originally created by Andrew Hansford from Thames-Coromandel and Andrew Mackay from Otago Regional Council. Once a National Welfare schema has been adopted, it will be used to re-design this Survey123 Form.
Link to XLSForm: http://www.arcgis.com/home/item.html?id=fb490ea4b64345b385a3c3807dca30c8
