I have 2 layers, one is township range polygons and the other is the section polygons, how do I add labels from the township range polygons to the section polygons within the section polygons? the finished map would have the township, range and section nu
754
12-13-2016 01:59 PM
JamesCannia
Because the base layers I have are separate township range polygons and section polygons how do i label the section polygons with he township range numbers and the section number? output would be: "T23N R15W 16"
JayantaPoddar
Maybe you would be interested in Spatial Join—Help | ArcGIS for Desktop .
Then you could build a Label Expression to define the desired expression.
Think Location
