How to make a time enabled map run in real time?
4328
5
07-07-2015 12:42 AM
EllenWildig
I am creating a map showing the movement of the tides at a specific site and therefore require the layers showing high low, incoming and outgoing tide to run in real time with tidal data. How do I go about doing this? I can make the layers run at arbitrary input times, they have date fields but how do I acquire and use real-time data? Thanks
ChrisSmith7
Honored Contributor
Regarding data, are you looking for something like this?
https://www.tidetimes.org.uk/all
Here's an example page - Aberdeen Tide Times | Tide Times  with RSS feeds at the bottom of each page - https://www.tidetimes.org.uk/aberdeen-tide-times.rss
Here's a tutorial on using RSS feeds:
http://www.arcgis.com/home/item.html?id=29f0689ec924498c9baf3bb2812dc78c
What would be really helpful is if you could find an all encompassing GeoRSS feed of tidal data, something like Recent UK earthquakes but for tidal data. I wasn't able find anything like this briefly searching. You might be able to join the data from the RSS, though. Honestly, I haven't done much with streaming data to a web mapping application, but am looking to do so in the future and so have been researching.
ChrisSmith7
Honored Contributor
I'm not sure where you are needing to do this, but if you are looking to deploy a web application using ArcGIS Server, have a look at this sample:
Stream Layer | ArcGIS API for JavaScript
Here's more info on the class:
StreamLayer | API Reference | ArcGIS API for JavaScript
And a presentation on the technology from Esri:
http://proceedings.esri.com/library/userconf/proc14/tech-workshops/tw_260.pdf
EllenWildig
Thanks, I'll take a look. The site is in the North of the UK.
ChrisSmith7
Honored Contributor
EllenWildig
Thank you so much for taking the time, It's a massive help.
ChrisSmith7
Honored Contributor
No problem! Another thing you could do is aggregate all of the RSS feeds using something like RSS Mix (RSS Mix - Mix any number of RSS feeds into one unique new feed! ), to get something like
My feed. It might make getting all of your targeted locations easier.
