How do i export csv file with coordinates to arcgisonline
1698
04-27-2018 01:07 PM
ShehuBello
How do i export csv file with coordinates to arcgisonline?
AdrianWelsh
MVP Honored Contributor
Shehu,
There are a few ways to do this. Follow the directions here:
Add a layer from a CSV file—Get Started with Map Viewer | ArcGIS
Also, more information can be found regarding CSV requirements here:
CSV, TXT, and GPX files—ArcGIS Online Help | ArcGIS
AdrianWelsh
Shehu,
ShehuBello
Thank you Sir.
AdrianWelsh
No problem. I hope this helps and using a CSV in ArcGIS Online can be a relatively simple process. That is, of course, if your data is exactly as ArcGIS Online expects. Play around with it some and plot some points.
