Wpf Crashed related to runtimecore.dll
2956
8
01-06-2025 08:44 AM
Labels (3)
StevenLam1208
Does anyone have an issue with an application automatically closed in version 200.6?  I got the exception from an application event viewer log.  It is affecting our production application.Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.AccessViolationException
at RuntimeCoreNet.GeneratedWrappers.CoreVector.CoreRT_Vector_insert(IntPtr, Int64, IntPtr, IntPtr*)
at RuntimeCoreNet.GeneratedWrappers.CoreVector.Insert(Int64, RuntimeCoreNet.GeneratedWrappers.CoreElement)
at Esri.ArcGISRuntime.RuntimeCollection`1[[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]].AddRange(System.Collections.Generic.IEnumerable`1<System.__Canon>)
at Esri.ArcGISRuntime.RuntimeObservableCollection`1[[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]].AddRange(System.Collections.Generic.IEnumerable`1<System.__Canon>)
StevenLam1208
The application has been running for a while then it intermittently closed.  The application displays the incident locations and moving vehicles using graphicsoverlay.  I tried rendering mode Static v.s. Dynamic.  It still had the same issue.
dotMorten_esri
Esri Notable Contributor
That does indeed look like a crash deep in the native code. Do you have somewhat of a consistent reproducer? If so we might be able to tweak a few settings and collect a good crash dump to help investigate.
StevenLam1208
It is randomly closed.  I am not able to reproduce it consistent.
StevenLam1208
No, I don't.  It ran for several days, then crashed without any action.  Do you have any suggestions?
StevenLam1208
I was able to capture the dump files that happened several times during this weekend using Procdump.  I attached these dump files via ESRI case #03817866.
dotMorten_esri
Thank you! Very helpful. Already looked at them and having a code owner of the specific area looking into it now.
StevenLam1208
Thank you very much for looking at this.
StevenLam1208
Hi Morten,
We changed our production application followed ESRI tech. support suggestion.  We used unique value renderer and PictureMarkerSymbolLayer.  We still have the runtimecore exception c0000005.  We have a bug number BUG-000174246.  Do you know the status of this?  We have complaints everyday that the application crashed.  All the crashes related to this exception.
