Why does ArcGISMapImageLayer lock MapView ZoomIn on MaxScale?
2743
11-24-2016 07:45 AM
RomanTrojan
ArcGISMapImageLayer locks MapView ZoomIn on MaxScale.
https://services.arcgisonline.com/ArcGIS/rest/services/World_Physical_Map/MapServer
MaxScale should set the maximum scale where the layer is visible, not to lock ZoomIn.
DominiqueBroux
Esri Frequent Contributor
By default the map scale range is set with the scale range of the first layer.
This prevent from zooming at a scale where no layers are visible.
You can change this behavior by setting explicitely the min/max scale of the map.
DominiqueBroux
RomanTrojan
Thank you Dominique, it works.
However, it is not clear approach for me to prevent from zooming all other layers in the map appointing to the first layer visible scale range.
