Use ExportTileCacheTask catch a exception
4478
12
06-21-2017 05:35 AM
xiaoguangyan
when I execute "await ExportTileCacheTask.CreateAsync(basemap.Source);" catch a Invalid response: Service does not support tile export. I use map in https://www.arcgis.com/home/group.html?owner=esri&title=Tiled%20Basemaps&start=11&q  for export also catch this exception
Tags (1)
AnttiKajanus1
Can you give the exact code / url that you are using? Following seems to work without any problems.
var task = await ExportTileCacheTask.CreateAsync(
    new Uri("https://tiledbasemaps.arcgis.com/arcgis/rest/services/World_Street_Map/MapServer"));
Remember that you shouldn't use the service "For export" services as your basemaps, they are intended to be used for taking tiles offline and not visualization.
xiaoguangyan
Hi, Antti
I just tested your uri, it will catch the "Token Required" exception
AnttiKajanus1
That is expected if you haven't signed in to ArcGIS Online since the export tiles feature is available to subscribed users (operation doesn't consume credits but you have to be signed in to have a access to it).
AnttiKajanus1
xiaoguangyan
Thanks, Antti.
xiaoguangyan
AnttiKajanus1
Can you sign into the ArcGIS Online with your credentials? If you sign in to https://www.arcgis.com/home/signin.html does the authentication go through without any problems?
xiaoguangyan
Yes, Antti, I can sign in without problems
AnttiKajanus1
Can you try if this works? Just change it to use your credentials.
 public partial class MainWindow : Window
        public MainWindow()
            InitializeComponent();
            AuthenticationManager.Current.ChallengeHandler = new ChallengeHandler(CreateKnownCredentials);
            Initialize();
        private async void Initialize()
            try
                var task = await ExportTileCacheTask.CreateAsync(new Uri("https://tiledbasemaps.arcgis.com/arcgis/rest/services/World_Street_Map/MapServer"));
            catch (Exception ex)
                // Something unexpected happened, handle properly
                MessageBox.Show(ex.Message);
        private string _username = "abcd";
        private string _password = "1234";
        private async Task<Credential> CreateKnownCredentials(CredentialRequestInfo info)
            // If this isn't the expected resource, the credential will stay null
            Credential knownCredential = null;
            try
                // Create a credential for this resource
                knownCredential = await AuthenticationManager.Current.GenerateCredentialAsync
                                        (info.ServiceUri,
                                         _username,
                                         _password,
                                         info.GenerateTokenOptions);
                // Report error accessing a secured resource
                MessageBox.Show("Access to " + info.ServiceUri.AbsoluteUri + " denied. " + ex.Message, "Credential Error");
            // Return the credential
            return knownCredential;
