Use ExportTileCacheTask catch a exception
4762
12
06-21-2017 05:35 AM
xiaoguangyan
when I execute "await ExportTileCacheTask.CreateAsync(basemap.Source);" catch a Invalid response: Service does not support tile export. I use map in https://www.arcgis.com/home/group.html?owner=esri&title=Tiled%20Basemaps&start=11&q  for export also catch this exception
Tags (1)
xiaoguangyan
Hi, Antti
I change the username and password to mine and run, it will also catch the "Token Required" exception.
AnttiKajanus1
Do you see credentials being created? If you check knownCredential does it have token assigned to it?
AnttiKajanus1
Do you have any proxies or similar in the middle?
