Unable to open a mobile scene package (or maybe create it?)
1852
04-26-2019 10:25 AM
MichaelHamsa
I'm trying to open up a mobile scene package with a point cloud layer (LAS) and I'm having some trouble. I've pulled a sample LAS dataset file down from the HI government site and loaded it up into a 3D Scene in ArcGIS Pro. From there I used the Create Mobile Scene Package geoprocessing tool to create an mspk, After that I attempted to load the scene package up onto a Runtime SceneView but the MobileScenePackage doesn't have any "Scenes" in it. I'm either not creating the scene package correctly in Pro or I'm not loading the scene package correctly in Runtime.
Here's the code I've got that loads up the scene package:
Esri.ArcGISRuntime.UI.Controls.SceneView sceneView = new Esri.ArcGISRuntime.UI.Controls.SceneView();
ControlSpace.Children.Add(sceneView);
MobileScenePackage mspk = new MobileScenePackage(FileName);
mspk.LoadAsync();
sceneView.Scene = mspk.Scenes.First();
Seems pretty straight forward, but I'm just not getting it.
Mike...
Andrew--Johnson
Hi Mike,
I imported this back into ArcGIS Pro and it displays just fine. The issue here is that it is a local scene. ArcGIS Runtime only supports global scenes so all you need to do is recreate the mobile scene package using a global scene as input to the GP tool. Let me know if you have any other problems.
thanks,
Andrew
MichaelHamsa
Andrew,
It’s taken a bit but I’ve finally circled back around to this. I recreated the mobile scene package using a global scene instead of a local scene and I still seems to be having the same problem. Once I create the MobileScenePackage and LoadAsync, there are no Scenes in the list.
I’ve attached my new scene package created from the global scene in Pro.
Mike Hamsa
Chief Technology Officer - GeoSpatial Innovations, Inc.
P: 512-982-6735
MichaelHamsa
Andrew,
Scratch that – wasn’t awaiting the LoadAsync.
Seems to be working just great!
Thanks a lot for the help on this.
Mike Hamsa
P: 512-982-6735
Andrew--Johnson
Thanks for the update and glad to hear it's working!
-Andrew
