Unable to load WMS layer without defining basemap
1554
11-17-2022 08:43 AM
ZachRuiz
I have a WMS layer I need to render in my application but for some reason it does not want to render unless I have set a basemap. This sadly will not work for me as I need the application to work offline I have followed the WMS layer (URL) example to a tee and the only way I can make the layer show is if I have defiend a basemap style.
I have tested that it is possible to add a WMS layer without a basemap by using the example from the sample app and that works fine.
Working Code:
private readonly Uri _wmsUrlVFR = new Uri("https://wms.chartbundle.com/mp/service?SERVICE=WMS&REQUEST=GetCapabilities");
private readonly List<string> _wmsLayerNamesVFR = new List<string> { "sec_3857" };
private async void Initialize()
            Map myMap = new Map(BasemapStyle.ArcGISDarkGray);
            // Add the map to the mapview.
            MyMapView.Map = myMap;
 private void Button_Click(object sender, RoutedEventArgs e)
            // Create a new WMS layer displaying the specified layers from the service.
            _VFRChart = new WmsLayer(_wmsUrlVFR, _wmsLayerNamesVFR);
            MyMapView.Map.OperationalLayers.Add(_VFRChart);
Not working code:
            Map myMap = new Map();
You will see the only difference is line 8
Tags (3)
ZachRuiz
Map myMap = new Map(SpatialReferences.WebMercator);
ZachRuiz
Ah, I need to set the spatial reference.
ZachRuiz
