The samples are not building for Xamarin.iOS
5020
6
11-28-2016 09:09 PM
YashvitNaik
Anyone stuck with this error on build? Using Esri.ArcGISRuntime.Xamarin.iOS v100.0.0
MTOUCH: error MT5209: Native linking error: framework not found ArcGIS-sim64
MTOUCH: error MT5202: Native linking failed. Please review the build log.
I'm on latest version of Xamarin Studio for Mac(6.1.2 build 44) with Xamarin.IOS Version: 10.2.1.5 & XCode Version 8.1.
Have tried installing the Esri library from local nuget package(installed the vsix on visual studio and extracted it from there) and also directly from nuget.
The samples from github seem to build fine for Android but NOT iOS.
RichZwaap
There was an issue with how the iOS and Android samples were referencing the ArcGIS Runtime assemblies.  This should be fixed now - please pull latest source from the samples repository and try again.  Sorry for the inconvenience.
-Rich
SchuylerDuarte
I wonder if this is related the same issue I was having.  Try changing the iOS Build options linker behavior to "Don't Link" as answered in my post:
Default constructor not found for type Esri.ArcGISRuntime.Xamarin.Forms.MapView
RichZwaap
-Rich
liknhwfw_egf
i am using xamarin form and calling your sdk via dependency service in both ios and droid
droid works fine but ios keep generating this error at build
what should i do?
MichaelBranscomb
Esri Frequent Contributor
Are you referencing ArcGIS Runtime SDK for .NET NuGet package that targets Xamarin Forms? (NuGet Gallery | ArcGIS Runtime SDK for .NET - Xamarin.Forms 100.0.0)
Cheers
Mike
liknhwfw_egf
yes , iam
VladPredovic
Hello I am having the same error.
I am developing on VS 2017 Windows machine linked to a mac. my applications builds and runs well on Android (verified after multiple QA runs).
However we are getting this native linking error when building on IOS. Using the newest version of ESRI maps nuget package for .NET. Both ESRI.Forms and ESRI.IOS are installed through nuget and I have tried both versions available just in case. Any help would be appreciated.
Error Native linking error: framework not found ArcGIS-sim64 RT.iOS C:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\MSBuild\Xamarin\iOS\Xamarin.iOS.Common.targets 747
Error Native linking error: warning: directory not found for option '-F/Users/vlad/Library/Caches/Xamarin/mtbs/builds/RT.iOS/9bd34334c2bb0c14c8bdf794fb67e9fc/framework'
