SLPK (LAS Dataset) in ArcGIS Runtime 100.1
2138
08-05-2017 11:38 PM
JackHansen2
I've been trying to follow a few ArcGIS Runtime 100.1 tutorials and samples. Basically I want to display a SLPK in a Scene. The SLPK has a LAS Dataset inside it. Is this supported yet? I seem to remember point clouds not being supported in previous releases. Morten Nielsen
MainWindow.xaml.cs
using Esri.ArcGISRuntime.Mapping;
using Esri.ArcGISRuntime;
using System.Threading;
using System;
namespace SLPK_TEST_NET_V1
/// <summary>
/// Interaction logic for MainWindow.xaml
/// </summary>
public partial class MainWindow
public MainWindow()
InitializeComponent();
// Execute initialization
Initialize();
public void Initialize()
// Create new Scene
Scene myScene = new Scene();
// Set Scene's base map property
myScene.Basemap = Basemap.CreateImagery();
// Create new scene layer from the url
ArcGISSceneLayer sceneLayer = new ArcGISSceneLayer();
Uri sceneURI = new Uri(@"C:\\Miscellaneous\\SLPK Test\\4043695.slpk");
sceneLayer.Source = sceneURI;
sceneLayer.LoadStatusChanged += myScene_LoadStatusChanged;
loadStatusLabel.Content = sceneLayer.LoadStatus.ToString();
if (sceneLayer.LoadStatus == LoadStatus.Loaded)
double lat = sceneLayer.FullExtent.GetCenter().X;
double lon = sceneLayer.FullExtent.GetCenter().Y;
double height = sceneLayer.FullExtent.GetCenter().Z;
// Add created layer to the operational layers collection
myScene.OperationalLayers.Add(sceneLayer);
// Create a camera with coordinates showing layer data
Camera camera = new Camera(lat, lon, height, 345, 65, 0);
// Assign the Scene to the SceneView
MySceneView.Scene = myScene;
// Set view point of scene view using camera
MySceneView.SetViewpointCameraAsync(camera);
void myScene_LoadStatusChanged(object sender, Esri.ArcGISRuntime.LoadStatusEventArgs e)
// Update the load status information
Dispatcher.BeginInvoke(
new ThreadStart(() =>
loadStatusLabel.Content = string.Format("Scene Layer' load status : {0}", e.Status.ToString())
MainWindow.xaml
<Window x:Class="SLPK_TEST_NET_V1.MainWindow"
xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
xmlns:esri="http://schemas.esri.com/arcgis/runtime/2013"
SizeToContent="WidthAndHeight"
Title="MainWindow" Height="350" Width="525">
<Grid>
<Grid.RowDefinitions>
<RowDefinition Height="auto" />
<RowDefinition Height="*" />
</Grid.RowDefinitions>
<esri:SceneView x:Name="MySceneView"/>
<StackPanel Orientation="Horizontal">
<Label x:Name="loadStatusLabel" Content="Scene Layer' load status : " Background="Yellow"/>
</StackPanel>
</Grid>
</Window>
RexHansen
Hi Jack,
   Scene layers from SLPKs that contain 3D objects or an integrated mesh are supported for use in Runtime 100.1.  Use of point clouds in a SLPK is not supported yet.  It will be supported in an upcoming release.
ManelKEDDAR
Please can you tell me if we can display ArcGISSceneLayers using .SLPK with lite license (arcGIS for developer program) ? how about to edit the scene Layers precisely  create new 3DFeature ?
Thanks in advance
