Share layer from ArcMap as an edit able Geodatabase?
3244
09-19-2015 12:10 PM
BehzadRouhieh1
If I share a layer from ArcMap as Geodatabase, How can I make it editable using ArcGIS Runtime in .NET (I have basic license and I only need to be able to edit it offline)?
AnttiKajanus1
Creating geodatabases using Desktop workflow creates read-only geodatabases, if you want to edit a geodatabase, you need to create it through FeatureLayer (you can create sync enabled geodatabase before providing it to the application if needed too, this is called "pre-planned" workflow).
Read more
https://developers.arcgis.com/net/desktop/guide/create-an-offline-map.htm#LI_2FB791B0031F4D129B0EAD2...
Sync offline edits—ArcGIS Runtime SDK for .NET | ArcGIS for Developers
