Shapefile loaded via ShapefileTable is crashing the application
3300
10-14-2014 09:21 AM
LukePatterson
I have one particular shapefile that is crashing with an access violation when added via the ShapefileTable method. The same shapefile loads fine when added as a dynamic map service layer. Verified the crash also occurs in the demo application.
Where can I send the shapefile/submit a bug?
FreddieGibson
Honored Contributor
Were you able to get an issue logged for this?
