Runtime preview for actual .net MAUI version
1498
07-18-2022 02:00 AM
Dabenes
Hi, im currently developing an app with ArcGis Runtime on .net MAUI. I was using the preview 3 for last Maui version but, since preview 3 no longer displays the map and Maui has a new release version, i was wondering if there will be a new update/version of arcgis runtime on close term, and when it would be if that was the case.
Thank you
dotMorten_esri
Esri Notable Contributor
Could you provide some more details on this? What issue are you hitting?
That shouldn't be an issue. You can use the newer version with Preview 3.
Wrt new releases, we plan on another preview with the upcoming  Update 15 release.
JoeHershman
See this thread Code to use MAUI (until official support in ArcGIS Runtime for .NET) which @SomeGISGuy has been commenting on.
Seems they are doing their best to keep up with a moving target.  Other XF APIs I am working with seem to be having similar struggles moving to MAUI
-Joe
dotMorten_esri
