Request for example Map Package (.mpk) data for using with LocalMapService
1821
02-27-2017 02:04 AM
Jesper_SlothChristensen
I am in the process of adding support for more map file formats in our application which uses ArcGISRuntime v100.0. I am currently trying to do this by starting a LocalServer and adding a LocalMapService to it. The idea is that a client can convert from a number of formats into a .mpk file in ArcMAP, which we can then add to our application by using the LocalServer. However, I don't have a lot of experience in using ArcMAP, so I am spending a lot of time trying to create som test data. Is there somewhere I can download some test data from, that could help me test my implementation of LocalMapService?
JenniferNery
Any sample data that came with your ArcMap install can be shared as runtime content. The following links might help: ArcMap - Creating ArcGIS Runtime content and ArcGIS Runtime SDK for .NET Guide - Local Server
