RasterLayer from TIF file not reading metadata .xml
543
09-25-2025 11:58 AM
YasunariTosa1
Reading a USGS created tif file (n10_ak.tif) with metadata .xml (n10_ak.tif.xml) by RasterLayer ctor.  The result of RasterLayer SpatialReference and FullExtent.SpatialReference are both null.  ArcGISPro v.3.41 read it and no problem showing in map.  Interestingly another USGS created tif file (USGS_SIM-3340_1.tif) and metadata xml (USGS_SIM-3340_1.tif.aux.xml) are read by RasterLayer and have SpatialReference correctly set.   The format of xml file is different between the two.  Is there a way to n10_ak.tif to have a spatial reference read?   RasterLayer SpatialReference and FullExtent.SpatialReference are getter only.   I cannot post tiff files with associated xml files, since the file extension is tif and xml are not supported and the file size is bigger than 9MB.
YasunariTosa1
For people curious for the file is below:
https://www.sciencebase.gov/catalog/item/65ccea5bd34ef4b119cb3bac
Slope-Relief Threshold Landslide Susceptibility Models for the United States and Puerto Rico
n10_susc.zip which contains n10_ak.tif and n10_ak.tif.xml
ArcGISPro has no problem reading the file and show on the map.
