Query all ENC features on a single click
637
12-17-2025 03:14 AM
MattAshman96
I have this code that works well for querying the ENC feature that is clicked on.
What I want to do, is be able to display information on every feature that is located at the clicked-on point (common case is you have a buoy with a light, so I want to be able to display the information about the light and the buoy). I would create a custom popup window for this.
I would have thought I'd achieve this by iterating through the firstResult.GeoElements list - but that only contains the feature at the top level and not all the features underneath as well.
Is there any way to achieve what I am after?
Thanks
IReadOnlyList<IdentifyLayerResult> results = await _mapView.IdentifyLayersAsync(e.Position, tolerance, false);
IEnumerable<IdentifyLayerResult> encResults = results.Where(result => result.LayerContent is EncLayer);
IdentifyLayerResult firstResult = encResults.First();
EncLayer containingLayer = (EncLayer)firstResult.LayerContent;
EncFeature encFeature = (EncFeature)firstResult.GeoElements.First();
containingLayer.SelectFeature(encFeature);
StringBuilder sbAttr = new StringBuilder();
foreach (var item in encFeature.Attributes)
				sbAttr.AppendLine(item.Key + ":  " + item.Value);
CalloutDefinition definition = new CalloutDefinition(encFeature.Description, sbAttr.ToString());
_mapView.ShowCalloutAt(e.Location, definition);
GKmieliauskas
As specified in the documentation, your IdentifyLayersAsync method initiates an identify operation on all layers in the view which will return the single visible topmost geoelement per layer only.
There is overload of IdentifyLayersAsync method which allows you to specify the maximum number of geoelements to return per layer:
public Task<IReadOnlyList<IdentifyLayerResult>> IdentifyLayersAsync(Point screenPoint, double tolerance, bool returnPopupsOnly, long maximumResultsPerLayer, CancellationToken cancellationToken)
Or you could try to use spatial query to get all features at the clicked point.
GKmieliauskas
MattAshman96
Thank you for the reply - I have implemented your suggestion with the overload and it works as expected. Cheers!
